loose wireless strength within same room by 75% in 15 ft. No obstructions
Jangittings2024
Jangittings2024 Posts: 1 Newcomer
edited December 14 in Connectivity
    Edward_T Posts: 100 ✅ Verified Employee Moderator
    Hello @Jangittings2024;
    I do apologize that the range has not been great in your room. I logged into your Spectrum router and optimized the settings to see if it helps resolve the issue. If you still continue to have issues with the WIFI range then I would recommend we get a technician out to check the WIFI health in your home.
