Home Digital Voice incoming call hard phone-number blocking
HT_Greenfield
Posts: 1,314 Contributor
Ref. 🔗 https://www.spectrum.net/support/home-phone/handset-calling-features-and-star-codes
↳ Calling Features (started services before 7/28/25) ↳ Block Unwanted Callers 🔍 👀
↳ Calling Features (started services after 7/28/25 or received a communication about a change in platform) ↳ Block Unwanted Callers 🔍 👀
Just curious if anybody from Spectrum can confirm:
- Is this hard-blocking technique still effectively available?
- Can a single entry block an entire exchange (NPA-NXX*) or an entire area code (NPA*) or is each entry limited to a single phone number (NPA-NXX-XXXX*) [*ref. NANP format]?
- Does this and Call Guard have anything to do with each other?
P.S.: No rush. (Just curious.)
P.P.S.: Never mind. It obviously doesn't hold candle to Call Guard. Just something (and not necessarily the only thing) for whomever it may concern to consider if they think Call Guard is blocking automated calls that Call Guard might have nothing to do with. ☘️
