Is there a way to view the saved speed dial numbers online?
There used to be, but now I don't see that option (unless I am not looking in the right place).
Hello @deedleann824
On our site, once you log in, you should see a tab that says "Services", from there you can select "Home Phone" and the old VoiceZone options are under the "Manage Voice" option.
I didn't see what you mentioned. I tried 'manage speed dialing' and got the message, "Page could not be found."
Once you log into spectrum.net, select home phone, then there are some options, your plan, calls, settings, and voices access. Under voice access click manage voice, it will take you to a voice zone. At the top click settings, it will then bring in some options the last one is speed dial.
I just don't see the links you mentioned using that info. This is where I had to go:
voicezone.spectrum.net/SummarySettings/SummarySettings
