RC122 Remote put Tv code on Aux for vizio soundbar
Hi to control a vizio soundbar, I need to program a vizio tv code to the aux button. Tv codes are only accepted on the tv button but I know other remotes allow you to force other buttons to accept tv codes. How do I force the rc122 remote to accept a tv code on the aux button?
I figured it out. The copy command on the RC122 is 992. The sequence is hold cable button and ok/select button for 5 seconds then hit 992 then I hit the TV button then I hit the AUX button. That copied the current tv code to the aux button.
After that I changed the TV button back to my actual TV's code. This allowed me to have 2 tv codes on the remote at the same time.
It's such a niche thing that I don't blame time warner for not having the copy command for the remote listed anywhere.
It should be useful for anyone with certain vizio soundbars. 1230 was the vizio tv code that was able to control it.
After that you need to setup all volume controls to goto the AUX button.
5
