Update Resolution Message
eznoh
eznoh Posts: 42 Contributor
Most every day when I turn on my Samsung TV and Spectrum DVR I get a message asking me if I want to update the resolution on the TV. It is alreadt set to the highest resolution but I select the "update" button and it supposedly updates the resolution, there is no actual change in the resolution and the next day I get the same message again. How can I get rid on this annoying message?
Mike
  • eznoh
    No it's by the DVR.
  • eznoh
    It wasn't happening as often as I thought ... here are screenshots for the message and system info.IMG_20200511_113924.jpgIMG_20200508_092528.jpgIMG_20200508_092435.jpg
  • eznoh
    You might need to sign in. I just looked my post and the images were not displayed, signed in and they showed up.
    Mike
  • Jkosar
    Jkosar Posts: 3 Rookie
    I get the same message. I select update and my resolution changes to 1080P.  I verify this by checking my TV display options. It is indeed 1080p.  And it's noticeable. Normally in settings I only have up to 1080i.
    But this message doesn't appear every time.
    Also, Sometimes when the full guide isn't working I get  an options to select the mini quick guide for settings. This guide gives me options for 1080p 1080i and 720 p. But I get only access to this guide when the standard full guide is unavailable for whatever reason.
    Why is 1080p only available in these two options, that are not regularly available?
    Thanks
  • Julia_R
    Does this box do this if connected to another TV> If you have multiple boxes do you see this happen on other boxes?
    Has the cable box been powercycled recently to rule that out?
    Julia
  • Jkosar
     My sony bravia 4K has the message appear after the box has been off for a while. If Im quick enough I can select to accept the higher resolution, otherwise if vanishes quickly.   But if i shut the tv off and then back on the message will not appear and I am back to  720p.
    My LG 1080P has asked once and the resloution according to the TV itself has reamined 1080P.
    I have repowered/rebooted the box.
    I dont mind getting the message, as I prefer 1080P..Its just that I want it to default to 1080P and I cant seem to do that.
  • Julia_R
    To access Video Settings:
    1. Press the Menu key on your remote.
    2. Select Settings & Support.
    3. Choose Preferences.
    4. Select Audio & Video.
    5. Go to Video and press OK/Select on your remote. From here, you can access:
      • Video Format: Select the screen resolution that’s best for your TV.
      • HD box on SDTV Aspect Ratio: Choose from Letterbox or Zoom.
      • SD box on HD Aspect Ratio: Choose from Pillar Bars or Stretch.
    6. Highlight Save and press OK/Select on your remote.
    Is that what you had done previously?  We would be looking to change the video format.
    Julia
  • eznoh
    I have done that, I set it to the highest resolution but in a couple of days I get the message again.
  • Jkosar
    I've done all that. However..in the settings,  there is no 1080P option. It seems its only available when this message appears upon startup or  within the quick setting menu, which i can only access when the standard guide is not available.   It is not an option in the standard menu.
    Why isn't 1080p a standard option if its obvioulsy available???
    Thanks!!!
  • Julia_R
    I am unsure why it would not auto set.
    One thought is that it depends on the programming you are viewing. If something is not available in that format perhaps it in a sense downgrades, when something then comes on which is broadcast in a higher resolution it asks.
    Have you swapped out HDMI cables between the TVs?
    Perhaps there is a communication issue with the TV not always offering that option so the box detects the changes and reverts to the lower resolution?
    I am sorry I do not have any further information on this available.
    Julia
  • eznoh
    The interesting thing is the resolution never changes if I select update or cancel.
  • eznoh
    The resolution never actually changes whether I select update or cancel. Not going to swap cables just to get rid of an annoying message that comes up every 3 days or so.
