How do I log out of unwanted devices?
I have someone that has access to my spectrum username and password, and I no longer want them to use it. When I change my password it does not prompt them to enter new information unless they log out manually. How do I remove unwanted users that have my info without them logging out manually?
Hello!
Welcome to the Spectrum Community!
After you have changed your password, and the app log has timed out with that previous one, it will force them to log back in. They wont be able to do this with the changed password. I do not have a time frame for when that will time out for them but once that happens they will be denied access.
Julia_R
5 -
On my Rokus, the certificates tended to last about a month, unless there was an update to an app--sometimes that forced a new certificate.
Would be nice if the Spectrum app tracked devices like the Hulu and Roku platforms... can actually disable individual device access. But that would likely be a big change for them to implement... worth running up the flagpole?
Is there any way to find out how long that time frame is? I want them to stop being able to use MY information immediately... if this is something that doesn’t happen until let’s say a month later then they’ll still be able to access MY services for an additional month when I no longer want them too.
Yes I’m currently on a call with spectrum in the streaming department who informed me that there’s no way for them to be kicked out unless they go in and manually log out themselves or uninstall and reinstall the app. Which I know they would never do JUST to have access to my services! Spectrum needs to fix this issue ASAP! I’m livid! They have me on hold with the retention/cancellation department to cancel my cable services all together JUST SO that way it FORCES the services to stop on the app that these other people that have my info have access too are using, then they are telling me to add services back on after a few days! They are really lucky I’m working from home or I’d cancel all my services with them all together and call it day! It’s ridiculous I have to go through all this just so that way those people can stop leeching off MY services that I PAY FOR!!!!!
Uggh... I cannot imagine the emotional roller coaster this has you on right now.
In the short term, may want to check out Pluto TV for some content during the downtime. They have apps for some platforms as well as browser based viewing. All Ad supported channels, a lot of independent and curated stuff... but they have a few sources for major outlets and such that may help fill some of the void.
Thank you so much🙏🏾
