Security Suite
claracourtney
claracourtney Posts: 3 Spectator
edited January 10 in Internet 2023 Archive
how can i get the secuirty suite
    Renee_T Posts: 693 ✅ Verified Employee Moderator
    Hello @claracourtney!
    Welcome to our community! You can download the security suite software for Windows from our support page. If you're using a Mac, not a PC, the Mac version can be found here.
  • claracourtney
    when i hit the dpwnload it does nothing
    James_M Posts: 4,791 ✅ Verified Employee Moderator
    That device are you using to download Security Suite?
  • claracourtney
    still cannot get the secuity suite , when i hit download it goes back to nicknsme again
    William_M Posts: 1,135 ✅ Verified Employee Moderator
    It is just "Download" you are clicking before it goes to nickname, not "Download Security Suite"?
    Is the nickname you are trying to use shorter than 16 characters and only consists of letters, numbers, dashes (-) or underscores (_)?
    After hitting download, do you see any error messages at the top of the page or anywhere else?
