My spectrum 201 dvr does not show the title of the shows that have been recorded. It shows "Title U
Posts: 2 Spectator
My spectrum 201 dvr does not show the title of the shows that have been recorded. It shows "Title Unavailable". So annoying. Rebooting does not help
Welcome!
  • Posts: 2 Spectator
    "Title Unavailable" is showing on the DVR list of recorded shows
  • Posts: 204 Contributor
    In our case, only some recorded programs show as "Title Unavailable". Sometimes getting "Info" on the recording clears some of them but not all.
  • Posts: 986 ✅ Verified Employee Moderator
    When you reset the cable box how did you reset it?
    I just did a "pull-the-plug" reboot on our 210H STB and it didn't resolve the matter. Here is some more information:
    1. Recorded Programs -7 episodes of "A" Haunting" Trvl Channel - #29.
    2. One Scheduled Recording - "Billions" Showtime - Channel #561
    3. Two Scheduled Recordings - Battlebots "DSCHD" -Channel #737
    4. One Scheduled Recording - "Bering Sea Gold" DSCHD Channel #737
  • Posts: 646 ✅ Verified Employee Moderator
    @catchtwentytwo
    Did this issue just start or has this always been the case?
    Been there for a couple of weeks, as best as I can remember
  • Posts: 1 Newcomer
    How did I fix the problem? Rebooting did not fix the problem
  • Posts: 6,149 Contributor
    Questions,
    1.) Does this only happen when the shows are set up as part of a series? Or does it also happen if you schedule the shows in question as individual recordings?
    2.) If they are set up as a series, what options are you using for series recording?
    3.) This might be a pain, but if the shows are set up as series recordings and showing "Title Unavailable" can you delete the series and reprogram the shows in question? Do you still get "Title Unavailable" after doing this, and the show has recorded completely?
    4.) Can you also provide screenshots?
    5.) If you have another box running the same software (Spectrum Guide, I presume?) does the issue also happen on the second box?
    Give your city, state, and zip code to help isolate the problem, or see if this is widespread?
