Apple TV+ replacement
ddcarr
ddcarr Posts: 1 Newcomer
I was offered the Apple TV+ unit for my kitchen tv when I first went with Spectrum cable system. The monthly fee for the Apple unit is much greater than the Xumo unit. Will the Xumo do as well as the Apple unit?
    Hello @ddcarr
    Welcome to our community! There are a few big differences between the Apple TV and the Xumo, but it would depend on what you're looking to use the box for. The biggest difference is that the Apple TV has access to the iOS App Store to download apps, where with the Xumo it has a set of preinstalled apps but does not have an app store to download additional apps. If you are primarily looking to watch the Spectrum TV app or individual network apps, than the Xumo would work well for you. If you're looking for a wide variety of apps and the ability to control which apps are or aren't installed, than the Apple TV may be the better option for you.
