Xumo
Gizmo1015
Gizmo1015 Posts: 1 Newcomer
I can’t figure out how yo record on my Xumo
    Hello @Gizmo1015
    Welcome to our community! To record on the Xumo, you would need to open the Spectrum TV app. Once the app is open you can either select the program from the guide and the record options would show in the programming details or you can search for the program and there should be a "Record" or "Record Series" option on the program description page. I find that searching is a little quicker, but some customers prefer going through the guide.
