Why am I getting repeated error message on outgoing mail fail?
99db_needshelp
99db_needshelp Posts: 2 Spectator
edited January 4 in Email
This is a new problem that started a few weeks ago. I get an error message in Outlook using spectrum e-mail. It looks like it is trying to send a message, except there is no message to send. Then error message shows up.
Task ----@---.--.com - Sending' reported error (0x8004210B) : 'The operation timed out waiting for a response from the sending (SMTP) server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP). The server responded: 550 5.1.0 <> sender rejected. The email address you are sending as must match the email address you used to auth. Please check your SMTP settings. AUP#Out-1500'
Can anyone help?
Thanks,
Dave
    Good evening @99db_needshelp and Welcome to our Community Forums,
    Thank you for reaching out to us. I am sorry this is happening when trying to send out an email using Outlook. Have you checked to make sure your Email server information is correct with Outlook? To determine which server information you should be using please visit Email Server information. If the information is correct, please try using our webmail option to see if you are able to send out emails. Please let us know if you need further assistance. -Lyn
    AUP 1500 means 'Your email was rejected for attempting to send as a different email address than you signed in under.' but it doesn't sound like you are trying to do anything like that. I recommend checking for Outlook updates, and removing re-adding the email account, or testing a different email client.
  • 99db_needshelp
    The email server information is correct and has not changed, including the complete e-mail address.
    Webmail is able to both send and receive.
    To clarify, I am able to both send and receive e-mails in Outlook. However, I continue to get the error message above every time Outlook does the send/receive action.
    HT_Greenfield Posts: 733 Contributor
    By now i think that your "username" as well as your email address in your baseline Outlook account settings will both need to be your de facto full Spectrum email address.
