Dynamic DNS
Peggy_Seldon
Peggy_Seldon Posts: 1 Newcomer
edited March 26 in Connectivity
Is there a DDNS provider that we know works with Spectrum Modem & Router, or does Spectrum provide DDNS configurations? How is DDNS enabled on Spectrum equipment? Want to remote desktop into my home computer.
  • RAIST515O
    RAIST515O Posts: 96 Contributor
    I use the one built into my Asus router... was hella convenient to set it up alongside the built-in VPN as well (builds a config file for importing into an OpenVPN client).
    Technically, any service should work just fine... depends more on the features you are looking for and how complex you want to make things, I guess.
