Spectrum Mobile wifi won't connect.
Posts: 5 Spectator
I switched from verizon to spectrum mobile this week with my factory unlocked S23+ and the Spectrum wifi auto-connect feature is missing and I'm asked to login when I click spectrum wifi. My family's s23 and s22 that were unlocked from verizon and brought over work fine. The s24+ from spectrum we got works fine, it's just mine.
Ive tried reinstalling the app over and over, rebooting the phone, got a new Sim card, backed up and factory reset the phone. Everything. It's not working. Attached is the feature that's missing.
Welcome!
  • Posts: 182 ✅ Verified Employee Moderator
    Hello @Ethan222.
    I can understand the frustration with getting your S23+ phone to connect to our Spectrum Wifi. You can find troubleshooting suggestions on the site below. I would recommend you look for other apps on your device that manages wifi and disable them. Once the software is disabled then reboot the phone and see if our Spectrum Wi-Fi Auto-Connect feature shows up.
    https://www.spectrum.net/support/mobile/connect-to-spectrum-wifi-automatically
  • Posts: 5 Spectator
    edited September 2024
    I tried all the troubleshooting steps, I even factory reset the device and started it from scratch with just the spectrum app and it still did not work. @Edward_T
  • Posts: 5,274 ✅ Verified Employee Moderator
    @Ethan222
    Not all devices are compatible with WiFi auto connect. BYOD devices are typically more finicky because they are configured to be compatible with the original providers networks. You should still be able to manually select the Spectrum Mobile WiFi and connect using your log in credentials. Once you log in, you can choose to have your credentials remembered by the device so next time you just have to choose the WiFi network.
    Let us know if you need anything else!
    Is there a domain I need to select or certain certificate? @James_M
  • Posts: 1,415 ✅ Verified Employee Moderator
    You shouldn't need to change that. Have you installed and signed into the My Spectrum app already?
    Yes. Randomly last night it just decided to start working, however the "auto connect" switch doesn't show in the settings still. Somehow I just went to a local business and bam it worked.
    I'm glad it's working! The My Spectrum app should enable the auto-connect function, even if the option doesn't exist in your devices settings. This should allow you to reduce your mobile data usage by a significant amount!
    It seems like sometimes it connects, but usually doesn't. I'll be right beside a spectrum mobile point and refresh my wifi search multiple times and it doesn't connect. Then maybe the next day it connects. It's very random and sporadic. @William_M
