Road Runner email
RSteiger
RSteiger Posts: 6 Novice
why is spectrum no longer supporting email and not allowing you to connect through on an iPhone or other apps and forcing customers to go to their website to view emails?
  • Mo_S
    Good afternoon and welcome @RSteiger,
    Email is still a supported service for those who already have an address with us. After June 13, 2024, we did cease offering email for any new customer or existing customer that had not yet set up an email account. You can still set up email on third party services using these email server settings. We do not offer support of email via third party services other than providing the server settings necessary for their use and limited troubleshooting as these are not our programs. Our only directly supported email client is via the webmail site and is used for verifying emails are working correctly. If they work via webmail, but not on your chosen third party email client with appropriate settings, you may need to contact them for assistance.
    Can you please verify the server settings you currently have set up on your iPhone or other mail client? You can post any screenshots necessary, omitting any email address or password.
  • RSteiger
    contacted support and was told as of last week spectrum no longer supports mail on iPhones mail app? My wife has same roadrunner email account and has no problem with emails on her iPhone. Her settings and mine are the same.
    Hello @RSteiger;
    You should still be able to use IPhone for our email but we do not directly support the Email application. We can provide you the settings but some issues will require you to contact Apple about. Can you provide us the error messages you are receiving and the settings you are using in the app?
  • RSteiger
    edited June 2025
    error messages are varied & sporadic. Some are as follows:
    Server not responding, connecting,
    Incorrect password
    Once or twice a day I will receive emails but it takes hours to download the content.
  • Mo_S
    @RSteiger,
    Both the incoming and outgoing host name/server should be mail.twc.com. The user name and password are needed for incoming/outgoing as well, and SSL also needs to be on for both.
  • RSteiger
    can you forward me all of the settings required?
  • Mo_S
    They're at the link provided above, but have also been sent by text to the number on the account.
  • RSteiger
    settings are set exactly as specified by link above but email not working.
  • Mo_S
    With the images you sent, it looks like some of the settings weren't correct. Were the items previously listed updated?
  • RSteiger
    as far as I can see the settings are the same. What did you see that are incorrect?
    William_M Posts: 1,846 ✅ Verified Employee Moderator
    edited June 2025
    For the outgoing mail server it looks like you have "mobile-smtp.roadrunner.com" set, which should be "mail.twc.com". Please also make sure the full email address is set as the username.
    If the issue persists, I recommend removing the email account from the mail app and re-adding it.
