Why did Paramount+ come up on my computer but not on my TCL ROKU?
2046CHAMLETb
Posts: 1 Rookie
When I try to activate Paramount+ on my ROKU it gives me 7 characters to enter, but there is only space for 4.
Hello @2046CHAMLETb;
Welcome to the Community Forums. The activation for Paramount+ should only have to be done on on device. Once it has been activated on your computer then you just need to log into the account you created on the Roku and it should work. If it does not let you enter enough characters for the login information then I would recommend you remove the app from the device and then add it back on.
