Why isn't there an advanced options page to select different wifi channels?
ccs46
ccs46 Posts: 3 Novice
edited March 8 in Home Networking
For whatever reason, the Spectrum Mobile SSID of my neighbors and their SSIDs for 5Ghz wants to keep sticking to 157.
Is there a reason that the SBE1V1K is not capable of switching to a different channel automatically or allowing a end user to change this setting?
I get it its simplified to reduce the amount of calls Spectrum gets because some screwed up their wifi, but I would expect this device to at least allow for rescanning manually to pick a better channel, especially in some congested environments such as townhouses.
Maybe require you visit the IP of the router to make the change versus the Spectrum app?
    HT_Greenfield Posts: 1,398 Contributor
    Forget about it. That's literally by Wi-Fi 6 802.11ax and now also Wi-Fi 7 802.11be channel "coloring" design and that particular hyper-coexistence black magic is not something to try to defeat.
    🔗 https://www.howtogeek.com/368332/wi-fi-6-whats-different-and-why-it-matters/ ↳ How Wi-Fi 6 Battles Congestion ↳ "You don't really need to know the details. … Wireless access points near each other may be transmitting on the same channel. … With Wi-Fi 6, wireless access points near each other can be configured to have different Basic Service Set (BSS) "colors." … so this will improve performance in congested areas, and is also called "spatial frequency re-use." […] "
  • ccs46
    edited March 22
    The buffer bloat the SBE1V1X seems to have is really really bad. Can spectrum engineers maybe take a look at some firmware that improves the QOS? It hasn’t gotten an update since January.
  • ccs46
    The bufferbloat the SBE1V1X seems to have is really really bad. Can spectrum engineers maybe take a look at the onboard QOS settings?
