Unstable internet connection for an extended period
Vitaly
Vitaly Posts: 2 Novice
Hi there! Could someone please tell me what I should do? The support team either tries to overwhelm me with questions—insisting that, according to their tests, everything is working perfectly on my end—or they threaten to charge me a fee for a tech visit. Here is the situation: I have been using Spectrum home internet via a coaxial connection for about three years. About a year or little more ago, I started experiencing outages: all my devices lose their internet connection for a few seconds every few minutes. Nothing seems to help; this pattern persists for several days, then everything works fine for a few days, and the cycle continues to this day. My entire family has switched to using mobile data and only connects to the Wi-Fi for urgent tasks. I, however, continue to use this terrible internet service and feel completely powerless to do anything about it. Whenever I contact support, they warn me that I will be charged a fee if the technician arrives and finds that everything is working. But that is exactly what happens—they show up when the connection happens to be stable. All I can do is show them screenshots and stability test results. They have replaced my router, but they refuse to replace the modem. The situation remains unchanged. I can neither use the internet effectively nor do I want to pay for a useless technician visit. What is actually going on? If the router isn't the issue, and it's not the Security Shield at work, then what could it be? How can I convince someone to actually fix my problem?
    Hey @Vitaly, welcome to our community! I'm sorry our internet service hasn't been working consistently. Everything looks good from our end, the modem is remaining online and signal strength is healthy. You are certainly welcome to try exchanging the modem at one of our stores. Do you notice any changes to the lights on it or the router when you lose connection?
    If we need to we can schedule an appointment with a technician, charges for appointments are very rare. Intermittent issues can sometimes take multiple appointments, especially if the issue isn't present when the technician tests, but if the issue lasts for days at a time I'm confident we can get a technician there within that period. We typically have same or next day appointments available.
    edited March 18
    Only to be taken with a grain of salt and generally only applicable to residential subscription top 1%-ers, biz-grade service would hopefully be worth consideration if even only for just a trial period to find out if it makes any difference.
    Potential rez top-1%-er clognosis: 🔗 https://www.spectrum.net/support/internet/network-management
    Biz fly: 🔗 https://www.spectrum.com/business/small-business/internet
    edited March 18
    What William said!
    P.S.: I'm a moron 🤡. My bad.
  • RAIST515O
    When things are going AWOL, have you tried connectng a PC or laptop directly to the modem with an ethernet cable? (Would plug it into the modem in the same ethernet port a seperate router would be using)
  • Vitaly
    Thanks, everyone, for your replies! I replaced the modem, and while stability improved, the actual internet quality remained poor—despite the fact that the speed tests in the Spectrum app were showing absolutely sky-high speed. I decided to resolve the issue once and for all: I bought a Netgear AX6 combo device. Now, three days later, no one in the family is complaining about the internet quality anymore, and nobody is having to rely on mobile data while at home! I returned the rented equipment, and now, finally, I have absolutely no complaints against Spectrum; the connection is stable, and the speed is excellent!
