Consistent Evening Packet Loss & Throughput Collapse - New Smyrna Beach Area (Since 4/30)
I am looking for help regarding a consistent, time-of-day-based service degradation that began around April 30th.
Prior to 4/30, service was stable. Since then, I am seeing massive spikes in packet loss (up to 60%) and a corresponding collapse in throughput every evening during peak hours.
Observed Symptoms:
- Packet Loss: Spikes between 11am to 6pm.
- Throughput: Drops from a stable 500+ Mbps to sub-100 Mbps (and occasionally near zero) during these loss events.
- Equipment: EU2251.
I have attached a graph showing the 30-day trend. You can clearly see the transition from stable service to the current daily failure pattern starting at the end of April.
Thank you.
Hello and welcome @robdr,
Reviewing your modem history, there are some concerns that began recently. I didn't see the modem has rebooted recently, so that would be a good start, but you'll likely need a technician scheduled to come out as well. We can set that up here for the first available appointment if you'd like, which you can then reschedule to a time that fits your needs if the first opening doesn't work for you. Just let us know.2 -
OK, let's schedule a technician to come out. I would like to schedule them to come out during a time when I'm expericing the issue.
