Netgear CM3000 v6.01.03 firmware causing T3/T4 timeouts - request v6.01.04 push
slackingaruda
slackingaruda Posts: 1 Rookie
I'm experiencing frequent service disconnections on my owned Netgear CM3000 modem since it was updated to firmware v6.01.03. My event log shows over 20 critical errors in the past 4 days, including:
  • Multiple T3 timeouts ("No Ranging Response received")
  • Multiple T4 timeouts ("Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received")
  • TCS Partial Service events
  • US Profile assignment changes (modem being downshifted between OFDMA profiles)
  • SYNC Timing Synchronization failures
These errors are happening at all hours of day and night, with disconnections occurring multiple times per day. The errors are characteristic of upstream signal/registration issues, but this pattern is documented across multiple CM3000 users on both Spectrum and Xfinity who received firmware v6.01.03.
This appears to be a known firmware regression. Netgear released v6.01.04 in November 2025 specifically to address the v6.01.03 issues. There's also precedent here: a similar v.03 firmware was previously pulled by Xfinity/Netgear in 2024 after the same pattern of complaints, with affected modems downgraded back to a working v5.x release.
Existing community threads documenting this issue:
  • Spectrum community: "Netgear CM3000 – Firmware v6.01.03 Causing Constant Disconnects"
  • Netgear community: "Now Spectrum has updated the CM3000 to version 6.01.03 - they refuse to roll it back"
  • Xfinity community: "CM3000 Slow Login with New Firmware (V6.01.03)"
Request:
Please either:
  • (a) Push firmware v6.01.04 to my modem, or
  • (b) Rollback my modem to v5.01.02 (the prior stable firmware), or
  • (c) Provide official acknowledgement of the v6.01.03 regression and a timeline for the fix
I can provide the full event log, modem MAC address, and account details via private message or ticket. I'd prefer not to swap to a rental gateway or replace my purchased equipment due to a firmware issue that has a known available fix.
Thanks for any help - I know firmware decisions sit with engineering, so any visibility this gets internally is appreciated
    Give it a factory reset (not just a reboot) and then, regardless of which version of firmware it ends up receiving from either the OEM or the ISP, if the faults persist, get a local tech house-call scheduled in case the root cause has to do with signal quality and/or provisioning.
    🔗 https://community.netgear.com/discussions/home-cable-modems-routers/spectrum-cm3000/2464374 : "[…] update. I don't know what changed because it's still showing firmware version V6.01.03 but as of today the CM3000 seems to have stabilized and appears to be working normally again on Spectrum. […]"
    🔗 https://www.reddit.com/r/NETGEAR/comments/1myf3g1/comment/nb177rl/ : "[…] a fix was pushed out late Monday or yesterday that took care of the issues on Spectrum at least. […] It's still showing firmware version V6.01.03 and it's now been working normally for over 30 hours with no issues and a totally clean empty event log."
