Intermittent Slow Speeds
Recent slow speeds with high latency for the last several days. Look at this tracert, hop 10 in particular, and you'll clearly see it's not on my end. It's been bolded and italiced. I also included another tracert, just a few minutes later, and it's performing just fine. Notice that server is no longer in the routing chain, almost like it was taken offline. My frustration is why does this keep happening, over the course of several days. If this was just a one off I wouldn't be posting. Opinions? Am I the only one seeing this?
--- Oct 1, 2026 3:26:02 PM
--- IP (wlan0) 192.168.1.3
--- IP (v4-rmnet16) 192.0.0.4
--- IP (rmnet16) 2607:fb91:17c3:d64b:ac39:c1b2:8425:9c7f
--- IP (rmnet17) 2607:fc20:8db1:9247:ad3:e80d:64da:4c84
--- Connection: WIFI
Trace to google.com
1 - 192.168.1.1
6 11 13 (ms)
Avg: 10 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
lag-60.dtr02bycymi.netops.charter.com
12 18 17 (ms)
Avg: 15 ms Loss: 0/3 (0 %)
4 - 96.34.32.126
lag-19.hcr02bycymifw.netops.charter.com
15 63 22 (ms)
Avg: 33 ms Loss: 0/3 (0 %)
5 - 96.34.32.64
lag-10.hcr01bycymifw.netops.charter.com
14 20 23 (ms)
Avg: 19 ms Loss: 0/3 (0 %)
6 - 96.34.32.108
lag-428.crr01sgnwmi.netops.charter.com
14 19 67 (ms)
7 - 96.34.2.56
lag-807-10.bbr01sgnwmi.netops.charter.com
20 27 22 (ms)
Avg: 23 ms Loss: 0/3 (0 %)
8 - 96.34.0.242
lag-806.bbr01ashbva.netops.charter.com
30 54 81 (ms)
Avg: 55 ms Loss: 0/3 (0 %)
9 - 96.34.3.51
lag-801.prr01ashbva.netops.charter.com
29 39 155 (ms)
Avg: 74 ms Loss: 0/3 (0 %)
10 - 68.112.12.17
syn-068-112-012-017.biz.spectrum.com
Loss: 3/3 (100 %)
11 - 192.178.45.33
40 85 97 (ms)
12 - 192.178.242.24
35 82 105 (ms)
13 - 142.251.49.189
31 34 34 (ms)
14 -
15 - 192.178.124.7
205 61 54 (ms)
Avg: 106 ms Loss: 0/3 (0 %)
16 - 142.251.234.37
131 153 60 (ms)
Avg: 114 ms Loss: 0/3 (0 %)
17 - 192.178.249.235
55 146 166 (ms)
Avg: 122 ms Loss: 0/3 (0 %)
18 - 142.251.231.67
47 98 53 (ms)
Avg: 66 ms Loss: 0/3 (0 %)
19 - 142.251.34.238
ncorda-an-in-f14.1e100.net
59 140 59 (ms)
Avg: 86 ms Loss: 0/3 (0 %)
Below is a good tracert, and how it should be.
--- Oct 1, 2026 3:42:57 PM
Trace to google.com
1 - 192.168.1.1
6 19 71 (ms)
Avg: 32 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
15 27 25 (ms)
Avg: 22 ms Loss: 0/3 (0 %)
4 - 96.34.32.126
16 47 66 (ms)
Avg: 43 ms Loss: 0/3 (0 %)
5 - 96.34.32.64
17 29 22 (ms)
6 - 96.34.32.108
14 61 18 (ms)
Avg: 31 ms Loss: 0/3 (0 %)
7 - 96.34.2.56
17 18 20 (ms)
Avg: 18 ms Loss: 0/3 (0 %)
8 - 96.34.0.242
30 35 79 (ms)
Avg: 48 ms Loss: 0/3 (0 %)
9 - 96.34.3.51
31 35 37 (ms)
Avg: 34 ms Loss: 0/3 (0 %)
10 - 72.14.219.176
32 33 32 (ms)
11 - 192.178.248.17
33 37 35 (ms)
Avg: 35 ms Loss: 0/3 (0 %)
12 - 192.178.248.40
36 54 39 (ms)
13 - 216.239.50.93
39 35 34 (ms)
Avg: 36 ms Loss: 0/3 (0 %)
14 - 142.250.215.191
35 103 89 (ms)
Avg: 75 ms Loss: 0/3 (0 %)
15 - 192.178.124.3
46 61 97 (ms)
Avg: 68 ms Loss: 0/3 (0 %)
16 - 209.85.241.122
84 70 69 (ms)
17 - 142.251.254.45
48 63 95 (ms)
18 - 142.251.231.245
52 299 103 (ms)
Avg: 151 ms Loss: 0/3 (0 %)
19 - 142.251.211.14
pnorda-am-in-f14.1e100.net
48 105 65 (ms)
Avg: 72 ms Loss: 0/3 (0 %)
I do apologize for the issues you're having with out internet service. From what I can see with the first trace route is that at hop 10 is when the signal transitions from our network to outside of the network. This is a normal result since the issues do not continue after hop 10 and do not show before that it means that specific edge router is designed to ignore trace routes so then would show a 100% packet loss. The second trace route shows a different location for hop 10 because hops are not always going to be the same. If you were to see issues before hop 10 consistently then the issue would be on our end.
I was able to find your account using your community login and the signal to your modem looks fine.
When you notice the service issues do you see the issues on all devices? Do you notice the issues only when doing certain things like streaming or gaming?
Thank you for getting back with me so quickly. I also called support, and I asked if I could send in my tracerts for Level 3. The support representative unfortunately stated that he felt the issue was with my end, and wanted to schedule a technician. He didn't know what a tracert was, and insisted that Spectrum doesn't have or lease any server bandwidth. I told them I would hold off on the service call, since the tracerts all show the slow downs happening well downstream from me most likely at one of Charter's Edge data centers. In answer to your question, the slow downs effect all of my connected equipment. It only happens during certain times of the day, but usually toward the afternoon. One thing that seems to be in common is that it occurs around hop 10, and that first server ip address is a major contributing player. I just ran another tracert showing that very same unresponsive server. I am also attaching a ping test as well to show the inconsistent latency along that route as well. Thank you for your time, and fast response.
--- Oct 1, 2026 6:09:54 PM
--- Connection: WIFITrace to google.com
1 - 192.168.1.1
5 63 64 (ms)
Avg: 44 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
14 64 34 (ms)
Avg: 37 ms Loss: 0/3 (0 %)
4 - 96.34.32.126
15 28 20 (ms)
Avg: 21 ms Loss: 0/3 (0 %)
5 - 96.34.32.64
19 20 67 (ms)
6 - 96.34.32.108
15 64 57 (ms)
Avg: 45 ms Loss: 0/3 (0 %)
7 - 96.34.2.56
13 25 72 (ms)
8 - 96.34.0.242
33 39 41 (ms)
9 - 96.34.3.51
42 43 41 (ms)
Avg: 42 ms Loss: 0/3 (0 %)
10 - 68.112.12.17
Loss: 3/3 (100 %)
11 - 192.178.45.33
30 36 34 (ms)
12 - 192.178.242.26
37 42 37 (ms)
Avg: 38 ms Loss: 0/3 (0 %)
13 -
14 - 142.251.237.185
39 39 38 (ms)
15 - 192.178.124.3
51 53 51 (ms)
Avg: 51 ms Loss: 0/3 (0 %)
16 - 216.239.57.76
55 157 61 (ms)
Avg: 91 ms Loss: 0/3 (0 %)
17 - 192.178.105.217
54 145 166 (ms)
Avg: 121 ms Loss: 0/3 (0 %)
18 - 142.251.61.41
55 58 95 (ms)
Avg: 69 ms Loss: 0/3 (0 %)
19 - 142.250.177.238
pnorda-an-in-f14.1e100.net
76 94 116 (ms)
Avg: 95 ms Loss: 0/3 (0 %)--- Oct 1, 2026 6:11:33 PM
--- Connection: WIFIPinging port 80 on google.com
1 time=87 ms, avg=87 ms
2 time=74 ms, avg=80 ms
3 time=119 ms, avg=93 ms
4 time=122 ms, avg=100 ms
5 time=58 ms, avg=92 ms
6 time=97 ms, avg=92 ms
7 time=69 ms, avg=89 ms
8 time=76 ms, avg=87 ms
9 time=124 ms, avg=91 ms
10 time=68 ms, avg=89 ms
11 time=120 ms, avg=92 ms
12 time=68 ms, avg=92 ms
13 time=75 ms, avg=87 ms
14 time=189 ms, avg=94 ms
15 time=72 ms, avg=95 ms
16 time=71 ms, avg=93 ms
17 time=129 ms, avg=99 ms
18 time=101 ms, avg=101 ms
19 time=71 ms, avg=96 ms
20 time=102 ms, avg=99 msmin=58 ms
avg=94 ms
max=189 ms
0/20 dropped: 0 %0 -
Just like cars on a highway or going through downtown, packets can simply get stuck in a queue. They typically are not actually getting discarded, but delayed here and there. It is why there are things like congestion control and lag compensation.
There is going to be jitter on the internet, especially as systems become more reliant on buffering to provide over the top high speed bursting.
If you truly need to keep jitter tightened as much as possible, may want to look into something like optimizing QoS through your router or other device.
https://www.waveform.com/tools/bufferbloathttps://www.waveform.com/tools/bufferbloat
Looking better this morning. Hopefully it looks similar this afternoon. 👍 Thank you Tyleen for your help. You taught me something about the Edge data centers, and how not all of the servers respond to ICMP echo requests. Below are this mornings figures.
--- Oct 2, 2026 10:32:40 AM
--- IP (rmnet16) 2607:fb91:17ed:6374:ac39:c1b8:9cd7:edd3
--- IP (rmnet17) 2607:fc20:8da8:af1f:ad3:e80d:7d57:c142
1 - 192.168.1.1
8 11 14 (ms)
Avg: 11 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
lag-59.hcr12bycymifw.netops.charter.com
15 36 20 (ms)
4 - 192.62.248.248
lag-20.hcr02bycymifw.netops.charter.com
17 74 31 (ms)
Avg: 40 ms Loss: 0/3 (0 %)
5 - 192.62.248.240
lag-47.rcr01antsmiad.netops.charter.com
25 39 29 (ms)
6 - 96.34.32.228
lag-6.crr01aldlmi.netops.charter.com
25 51 37 (ms)
7 - 96.34.2.8
lag-807-10.bbr01aldlmi.netops.charter.com
Loss: 3/3 (100 %)
8 - 96.34.0.139
lag-805.bbr01chcgil.netops.charter.com
Loss: 3/3 (100 %)
9 - 96.34.3.119
lag-811.prr01chcgil.netops.charter.com
Loss: 3/3 (100 %)
10 - 96.34.152.155
syn-096-034-152-155.inf.spectrum.com
Loss: 3/3 (100 %)
11 - 192.178.249.201
27 41 38 (ms)
12 - 142.251.231.247
30 41 38 (ms)
13 - 142.251.211.14
33 35 43 (ms)
Avg: 37 ms Loss: 0/3 (0 %)--- Oct 2, 2026 10:36:58 AM
1 time=36 ms, avg=36 ms
2 time=83 ms, avg=59 ms
3 time=88 ms, avg=69 ms
4 time=44 ms, avg=62 ms
5 time=94 ms, avg=69 ms
6 time=40 ms, avg=64 ms
7 time=47 ms, avg=61 ms
8 time=84 ms, avg=64 ms
9 time=44 ms, avg=62 ms
10 time=43 ms, avg=60 ms
11 time=44 ms, avg=61 ms
12 time=36 ms, avg=56 ms
13 time=53 ms, avg=52 ms
14 time=40 ms, avg=52 ms
15 time=49 ms, avg=48 ms
16 time=34 ms, avg=47 ms
17 time=49 ms, avg=47 ms
18 time=44 ms, avg=43 ms
19 time=47 ms, avg=43 ms
20 time=83 ms, avg=47 msmin=34 ms
avg=54 ms
max=94 ms
Back to terrible performance after decent weekend service. This is happening right at my local headend. I can't even stream music without frequent freezing, and rebuffering. 🤦♂️
Here is a tracert taken minutes ago, and it shows severe packet loss on Spectrum's end. Can you please advise on what these ongoing service disruptions are related to? How long will they continue to last? We have been loyal customers for over twenty-years. I would hate to have to jump to fiber over this ongoing issue. 😔 Thank you again!
--- Oct 5, 2026 10:18:48 AM
--- IP (wlan0) 192.168.1.29
--- IP (rmnet16) 2607:fb91:17c3:20f7:ad3:e852:8401:28f2
--- IP (rmnet17) 2607:fc20:8dc3:baeb:ad3:e80d:4b5a:4151
--- Connection: WIFITrace to tidal.com
1 - 192.168.1.1
8 10 56 (ms)
Avg: 24 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
78 48 (ms)
Avg: 63 ms Loss: 1/3 (50 %)
4 - 192.62.248.248
19 48 188 (ms)
Avg: 85 ms Loss: 0/3 (0 %)
5 - 192.62.248.240
46 143 (ms)
Avg: 94 ms Loss: 1/3 (50 %)
6 - 96.34.32.228
167 186 31 (ms)
Avg: 128 ms Loss: 0/3 (0 %)
7 - 96.34.2.8
Loss: 3/3 (100 %)
8 - 96.34.0.193
lag-905.bbr01chcgil.netops.charter.com
Loss: 3/3 (100 %)
9 - 96.34.3.9
lag-801.prr01chcgil.netops.charter.com
Loss: 3/3 (100 %)
10 -
11 -
12 -
13 -
14 - 15.230.192.12
Loss: 3/3 (100 %)
15 - 108.159.227.15
server-108-159-227-15.ord56.r.cloudfront.net
37 156 (ms)
Avg: 96 ms Loss: 1/3 (50 %)
16 - 108.159.227.15
187 34 (ms)
Avg: 110 ms Loss: 1/3 (50 %)
17 - 108.159.227.15
49 196 55 (ms)
Avg: 100 ms Loss: 0/3 (0 %)
18 - 108.159.227.15
171 (ms)
Avg: 171 ms Loss: 2/3 (200 %)
19 - 108.159.227.15
35 (ms)
Avg: 35 ms Loss: 2/3 (200 %)
20 - 108.159.227.15
166 37 (ms)
Avg: 101 ms Loss: 1/3 (50 %)
21 - 108.159.227.15
38 30 (ms)
Avg: 34 ms Loss: 1/3 (50 %)
22 - 108.159.227.15
32 178 (ms)
Avg: 105 ms Loss: 1/3 (50 %)
23 - 108.159.227.15
52 124 (ms)
Avg: 88 ms Loss: 1/3 (50 %)
24 - 108.159.227.118
server-108-159-227-118.ord56.r.cloudfront.net
31 175 (ms)
Avg: 103 ms Loss: 1/3 (50 %)
25 - 108.159.227.118
115 238 31 (ms)
26 - 108.159.227.118
29 32 34 (ms)
27 - 108.159.227.118
29 144 284 (ms)
Avg: 152 ms Loss: 0/3 (0 %)
28 - 108.159.227.118
29 42 (ms)
Avg: 35 ms Loss: 1/3 (50 %)
29 - 108.159.227.118
77 201 33 (ms)
Avg: 103 ms Loss: 0/3 (0 %)31 (ms)
Avg: 31 ms Loss: 2/3 (200 %)0 -
Thirty minutes and we're back to good, and looking great. Same exact servers too, you can check the ip addresses in bold again. This is frustrating. I just wish there was some communication about what's going on. 🤷♂️
--- Oct 5, 2026 10:55:08 AM
--- IP (rmnet16) 2607:fb91:17c5:437e:ac39:c1b2:6aef:2950
1 - 192.168.1.1
5 16 12 (ms)
2 -
3 - 159.111.168.140
15 77 19 (ms)
4 - 192.62.248.248
24 16 18 (ms)
5 - 192.62.248.240
24 30 39 (ms)
6 - 96.34.32.228
28 25 55 (ms)
7 - 96.34.2.8
Loss: 3/3 (100 %)
8 - 96.34.0.193
Loss: 3/3 (100 %)
9 - 96.34.3.9
Loss: 3/3 (100 %)
10 -
11 -
12 -
13 -
14 - 15.230.192.12
Loss: 3/3 (100 %)
15 - 108.159.227.118
26 34 29 (ms)
Avg: 29 ms Loss: 0/3 (0 %)
16 - 108.159.227.118
28 28 26 (ms)
Avg: 27 ms Loss: 0/3 (0 %)
17 - 108.159.227.15
26 29 28 (ms)
18 - 108.159.227.15
26 33 26 (ms)
Avg: 28 ms Loss: 0/3 (0 %)
19 - 108.159.227.15
27 30 28 (ms)
20 - 108.159.227.15
29 29 28 (ms)
21 - 108.159.227.15
31 33 29 (ms)
22 - 108.159.227.15
27 33 28 (ms)
23 - 108.159.227.15
28 31 42 (ms)
24 - 108.159.227.15
25 30 27 (ms)
25 - 108.159.227.15
28 30 29 (ms)
26 - 108.159.227.15
26 30 31 (ms)
27 - 108.159.227.15
36 33 30 (ms)
28 - 108.159.227.15
27 27 27 (ms)
29 - 108.159.227.15
30 28 27 (ms)
Avg: 28 ms Loss: 0/3 (0 %)28 32 33 (ms)
Avg: 31 ms Loss: 0/3 (0 %)0 -
Have you tried replicating the issue while bypassing the router and connecting directly to the modem?
Hi everyone. My last post on this, because I know I'm sounding like a broken record. Here we go back to bad again. James, in answer to your question, no I haven't because the tracert takes care of all that troubleshooting. It very clearly shows that my router connection is very stable, with no loss and sub ten millisecond latency, and that all of the degradation is occurring off-site (hop 4 is well downstream from my local network) at the ip addresses indicated in bold. You can whois them, and they all point to Charter managed. Although, I had the names resolved when I ran the tracert, so you don't even have to run the whois since it's right there as clear as day at the Bay City Charter server. Thank you for trying though. I will try and stick this out with Charter, but it's just very frustrating. 😔 Here's my tracert to Tidal again, as streaming music has become impossible with Charter dropping packets.. 🤦♂️
--- Oct 5, 2026 12:26:28 PM
1 - 192.168.1.1
5 9 7 (ms)
Avg: 7 ms Loss: 0/3 (0 %)
2 -
3 - 159.111.168.140
12 21 176 (ms)
4 - 192.62.248.248
18 164 (ms)
Avg: 91 ms Loss: 1/3 (50 %)
5 - 192.62.248.240
31 28 25 (ms)
6 - 96.34.32.228
29 25 170 (ms)
7 - 96.34.2.8
Loss: 3/3 (100 %)
8 - 96.34.0.193
Loss: 3/3 (100 %)
9 - 96.34.3.9
Loss: 3/3 (100 %)
10 -
11 -
12 -
13 -
14 - 15.230.192.12
Loss: 3/3 (100 %)
15 - 108.159.227.57
server-108-159-227-57.ord56.r.cloudfront.net
35 34 167 (ms)
Avg: 78 ms Loss: 0/3 (0 %)0 -
Trace routes often de-prioritize hops, showing packet loss that is not packet loss, just a lack of a response. There also appears to be some congestion, which is normal. If there was truly a network issue affecting delivery, it would be present on all subsequent hops. The final hop 15 shows no packet loss:
15- 108.159.227.57
35 34 167 (ms)
Avg: 78 ms Loss: 0/3 (0 %)Which means it was completed without an issue. If there is an issue with your router, it is possible that it is magnifying the normal congestion. Bypassing the router and connecting directly to the modem isolates any possible equipment issue with your router and is the next step in troubleshooting. Let us know how it goes.
James, if I didn't have any symptoms associated with a congested or degraded isp connection I would be inclined to agree with your last statement. Also, faulty equipment doesn't exhibit the symptoms I am having. This tracert, the first one which was from this morning, and shows loss prompegating to the final hope is not normal congestion by any means. I have been monitoring this intermittent situation for a week, and it is network related not my router. As I write this Spectrum is performing flawlessly. Unfortunately, due to character constraints I will have to paste it into the next comment. If you compare that two, you will easily see this is a Spectrum issue. Thank you for your time and hard work. In my many years of sales and technical support, some of those even spent at Charter, service isn't always recognized. I do appreciate you looking into not just my problem but everyone else you assist. 👍
1 - 192.168.1.1
8 10 56 (ms)
2 -
3 - 159.111.168.140
78 48 (ms)
4 - 192.62.248.248
19 48 188 (ms)
5 - 192.62.248.240
46 143 (ms)
6 - 96.34.32.228
167 186 31 (ms)
7 - 96.34.2.8
Loss: 3/3 (100 %)
8 - 96.34.0.193
Loss: 3/3 (100 %)
9 - 96.34.3.9
Loss: 3/3 (100 %)
10 -
11 -
12 -
13 -
14 - 15.230.192.12
Loss: 3/3 (100 %)
15 - 108.159.227.15
37 156 (ms)
16 - 108.159.227.15
187 34 (ms)
17 - 108.159.227.15
49 196 55 (ms)
18 - 108.159.227.15
171 (ms)
19 - 108.159.227.15
35 (ms)
20 - 108.159.227.15
166 37 (ms)
21 - 108.159.227.15
38 30 (ms)
22 - 108.159.227.15
32 178 (ms)
23 - 108.159.227.15
52 124 (ms)
31 175 (ms)
115 238 31 (ms)
29 32 34 (ms)
29 144 284 (ms)
29 42 (ms)
77 201 33 (ms)
Avg: 103 ms Loss: 0/3 (0 %)31 (ms) Avg: 31 ms Loss: 2/3 (200 %)
For comparison.. One beauty of a tracert! 👌
--- Oct 5, 2026 2:30:44 PM
1 - 192.168.1.1
6 15 10 (ms)
2 -
3 - 159.111.168.140
13 17 30 (ms)
Avg: 20 ms Loss: 0/3 (0 %)
4 - 192.62.248.248
28 31 34 (ms)
5 - 192.62.248.240
22 28 37 (ms)
6 - 96.34.32.228
25 38 39 (ms)
7 - 96.34.2.8
Loss: 3/3 (100 %)
8 - 96.34.0.193
Loss: 3/3 (100 %)
9 - 96.34.3.119
Loss: 3/3 (100 %)
10 -
11 -
12 -
13 -
14 - 15.230.192.12
Loss: 3/3 (100 %)
27 32 30 (ms)
33 31 27 (ms)
Avg: 30 ms Loss: 0/3 (0 %)
17 - 108.159.227.118
27 30 30 (ms)
18 - 108.159.227.118
30 29 26 (ms)
19 - 108.159.227.118
30 30 28 (ms)
20 - 108.159.227.118
28 29 30 (ms)
21 - 108.159.227.118
28 27 29 (ms)
22 - 108.159.227.118
27 27 29 (ms)
23 - 108.159.227.118
27 29 31 (ms)
26 28 33 (ms)
28 30 30 (ms)
31 30 26 (ms)
29 28 25 (ms)
27 27 27 (ms)
27 29 28 (ms)
Avg: 28 ms Loss: 0/3 (0 %)31 32 77 (ms)
Avg: 46 ms Loss: 0/3 (0 %)0 -
Packets are not getting discarded, but held in queues is what @James_M was describing. Not every application recovers gracefully from delayed/out of order packet delivery. One of the bigger risks (and drawbacks) of things like UDP to try to get less overhead and swifter transfers compared to TCP.
A large contributer to this is buffer bloating, which is often exacerbated by routers. Networks are becoming more and more dependent on burst transmissions, and extra layers of buffers can cause things to get sliced up in weird ways. If your jitter is becoming a problem, may want to look into something like QoS to try smoothing the timeslicing out better... not everything on your network needs to be thrust through at maximum speed, and if your network is doing that, packets that DO need higher priority may get queued behind slower traffic... because so much of your traffic is by default put on the wire as vanilla best effort, in FIFO order.
RAIST515O, thank you for your suggestion. However, my LAN jitter is great and typically my Spectrum WAN jitter is likewise very good. I manage my homes gigabit connection with approximately fourty clients. Since around 18:30 GMT things have been wonderful, again supported by much improved latency and tracert logs (see below). Hopefully they don't start messing with servers again tomorrow. Everytime I've had major internet slow downs it has been clearly indicated when I run a tracert. The problems were real, and they weren't client side they were clearly server side. Hopefully Charter keeps it sorted out. 🤞
--- Oct 5, 2026 8:39:52 PM
Pinging port 80 on tidal.com
1 time=33 ms, avg=33 ms
2 time=39 ms, avg=36 ms
3 time=52 ms, avg=41 ms
4 time=92 ms, avg=54 ms
5 time=47 ms, avg=52 ms
6 time=39 ms, avg=50 ms
7 time=94 ms, avg=56 ms
8 time=37 ms, avg=54 ms
9 time=49 ms, avg=53 ms
10 time=37 ms, avg=51 ms
11 time=46 ms, avg=53 ms
12 time=51 ms, avg=54 ms
13 time=47 ms, avg=53 ms
14 time=36 ms, avg=48 ms
15 time=46 ms, avg=48 ms
16 time=40 ms, avg=48 ms
17 time=50 ms, avg=43 ms
18 time=41 ms, avg=44 ms
19 time=51 ms, avg=44 ms
20 time=42 ms, avg=45 ms
min=33 ms
avg=48 ms
max=94 ms
0/20 dropped: 0 %
