Please Help Tier 3 Network Operations for Manhattan! [Detailed Analysis]
Jonathan
Jonathan Posts: 21 Contributor
edited October 13 in Connectivity
Please escalate this directly to Tier 3 Network Operations. Thank you!
Issue Summary:
  • Severe return-path impairment / CMTS uncorrectables resulting in complete loss of upstream OFDMA carriers.
  • Upload speeds dropping from provisioned 40+ Mbps down to ~500 Kbps/1 Mbps.
  • Event Log Alarms: Continuous repeating "UCD invalid or channel unusable", T4 timeouts, and SYNC Timing Synchronization failures.
  • Physical Line RF Levels (unpadded drop): Downstream raw power is running hot at +12.6 dBmV; upstream transmit drops down to ~25.5 dBmV.
Please check the neighborhood node's PNM (Proactive Network Maintenance) telemetry for return-path ingress/noise and high downstream RF.
Here are the Event Logs from my modem:
Critical DOCSIS Event Log Excerpt (Netgear CAX80 / DOCSIS 3.1):
Mon Oct 12 17:02:25 2026 | Critical (3) | UCD invalid or channel unusable;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:32 1970 | Critical (3) | UCD invalid or channel unusable;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:29 1970 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=[REDACTED];CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Mon Oct 12 16:17:27 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Mon Oct 12 16:17:26 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Mon Oct 12 16:17:18 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Mon Oct 12 15:35:19 2026 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:36 1970 | Critical (3) | DHCP FAILED - Discover sent, no offer received;CM-MAC=[REDACTED];CMTS-MAC=00:90:f0:27:00:00;CM-QOS=1.1;CM-VER=3.1;
Diagnostics & Plant Telemetry:
  • Upstream OFDMA Channel 1 dropped to Not Locked (0 Hz / 0 dBmV).
  • Upstream throughput collapsed to ~500 Kbps/1 Mbps due to severe return-path packet loss.
  • Raw unpadded drop RF levels: Downstream is excessively hot at +12.6 dBmV; Upstream transmits at ~25.5 dBmV.
  • Issue points to return-path plant impairment/noise ingress on CMTS node (00:90:f0:27:00:00) and an unbalanced outside street tap.
  • RAIST515O
    Reminds me when some workers exposed the coax and sheared off the outer shielding in my neighborhood one summer. Man that made a mess of the signal. Hopefully it is that obvious and just as "easy" to resolve.
    Hi @ Jonathan
    There was a known area issue impacting your service. The issue has cleared and everything looks to be working as expected as this time. If you see any other issues, let us know.
  • Jonathan
    @James_M My Upstream OFDMA Channels and four of my downstream channels aren't locking. Downstream power is running hot at +13-14 dBmV. My upstream drops to ~25.5 dBmV. Should I expect all 32 downstream channels bonded? Thanks.
    You are using your own modem, so troubleshooting is limited, Next step would be to schedule a tech visit.
  • Jonathan
    This is an outside issue. I have one six-foot coaxial cable connected from the PoE to my equipment, with no splitters. The downstream power running hot at +13-14 dBmV is on Spectrum's end. I wish you could resolve this on your end without a visit. I have one scheduled, but it is very inconvenient because of remodeling work I'm getting done.
