LEGACY EMAIL KNOWN ISSUE
spectrum.net
Problems with my Spectrum Remote
desertcliff
desertcliff Posts: 15 Participant
I switched over to Spectrum some months ago and the Spectrum technician programmed everything, including my remotes. On the TV I watch most frequently (a SONY Model 408X450), when using the Spectrum remote (I do not see a model number on the remote) and pressing the "all" button to power on the TV, I often have to press this button two, three or more times before the TV comes on and goes to a TV channel. This can't be right.
  • desertcliff
    Thanks, Satch. This one isn't a Smart TV, so there are no apps, etc. I'll try the other steps you recommended.
    HT_Greenfield Posts: 1,400 Contributor
    edited July 2023
    When you press ALL/Ȯ to turn the cable box and TV on or off and the TV doesn’t follow suit, don’t press it again but rather press TV/Ȯ to get the TV into the same on/off state as the cable box. My cable box never misses a beat with ALL/Ȯ while my TV often enough does yet it never misses a beat with TV/Ȯ so i gather that the TV occasionally fails to distinguish the second signal from the first of the two rapid-fire signals elicited by ALL/Ȯ which you can see the rapidness of by how rapid are the two blinks of the input LED. How often it happens depends upon the angle of the line of sight and who knows what else.
    Edit: if your cable box is a Spectrum “Worldbox” running the Spectrum Guide software and if you’ve not RF-paired the remote then you might be able to mitigate the effect by doing so.
  • desertcliff
    Thanks, HT_Greenfield. The cable box and remote were paired by a Spectrum technician.
    I'll try your suggestion re pressing TV/O. I should also mention that it takes quite a while before the TV and Spectrum come on. Perhaps pressing TV/O will speed that up.
  • desertcliff
    No better, I'm afraid, Satch. I just timed it and it took 24 seconds for the tv and box to come on. The TV is nearly ten years old, which I appreciate is almost ancient in this era of technology. However, I never had a problem with the TV or remote with DirecTV, which is about the only good thing I can say about DirecTV. I guess I can learn to live with having to press the button on the remote several times and waiting for everything to come on.
  • Unknown
    edited July 2023
  • desertcliff
    I'm afraid that the issue you've raised isn't limited to TVs by any means, Satch.
    Yes, I can live with things as they are. As they say, often you're better off with the devil you know!
    Just curious: When you turn on both the cable box and TV, does the TV sometimes ultimately display “no signal”? Is that what leads you to power cycle them? If so, I’d try a replacement HDMI cable and, in the meantime, try power cycling each by itself while the other remains on instead of both simultaneously in order to find out if it’s really only one of the two that needs to be power cycled in case such heuristic happens to correct the idiosyncrasy with fewer tries.
    You can power cycle the TV by itself via the remote TV on/off button and the cable box by itself (as inconvenient as such may be) via on/off button right on the front of the box.
  • desertcliff
    Yes, the TV sometimes ultimately displays "no signal" quite frequently.
    I've now tried to power cycle the TV and the cable box as you suggested, but same situation.
    While I very much appreciate all of the input I've received, to be candid I've spent far more time on this than it's worth to me. I can live with it as it is.
    My thanks yet again to everyone.
  • Unknown
    edited July 2023
