Will Verizon-version phones port to Spectrum Mobile or Unlocked only?
GregR
GregR Posts: 2 Novice
Hello! I'm looking to purchase a Google Pixel 3a and they come in Unlocked or Verizon. Will a "Verizon version" Pixel 3a work on Spectrum or do I need to get an Unlocked one? Anyone using a Verizon version Pixel with success on Spectrum Mobile?
    edited August 2020
    To check compatibility, you can go to spectrum.com/mobile and select BYOD. You will need to enter the IMEI. You can also contact Spectrum Mobile directly with specific questions about compatibility. They can be reached at (833) 224-6603.
  • GregR
    I understand the need to check IMEI, but is it generally safe to assume that if one "Verizon version" Pixel 3a phone shows as being compatible with Spectrum Mobile, then every Verizon version 3a will be similarly OK (assuming no issues/carrier-imposed locks etc)? Again, there appears to be two variants of this phone model, Unlocked and Version. Just trying to determine if I can safely purchase either variant for eventual use on Spectrum Mobile. Thanks for your help!!
