V8.8 cannot connect over WiFi IGE-9000
Mtfuji
Mtfuji Posts: 2 Novice
Had this issue on 8.7 , I upgraded to latest version wen I launch the app it errors out unable to complete request. IPad Pro 12.9 iOS 14.0.1, iPhone 11 Pro iOS 14.0.1. I am on m Spectrum WiFi and cannot connect. Same issue happens with My Spectrum app, I also cannot sigh in to Spectrum.net login never returns. Continue to be unable to use app
  • Julia_R
    Good morning @Mtfuji Welcome the the Spectrum Community!
    When you say login never returns, are you seeing a blank screen or does it go to that IGE-9000?
    Are you able to use your login at Spectrum.net on other devices or are you getting a loop-back or error?
    Julia_R
  • Mtfuji
    In the spectrum TV app it returns the IGE-9000 error. In the my spectrum app it never return just see spinning in progress. I tried other devices and direct connected PC via Ethernet cable to router and spectrum.net login does not finish just have spinning wheel
  • Julia_R
    I have private messaged you. The issue you are having sounds like a username issue. We will be able to look into that with you once we have gotten some more information from you.
    Julia_R
  • Community_Help
    Community_Help Posts: 48 ✅ Verified Employee Moderator
    The issue turned out to be a modem authentication issue and was resolved by rebooting the modem and router.
