Confused about authorized modems and WiFi charges
In order to have WiFi and not be charged $5.00 a month, I understand you need your own router compatible with Spectrum. If you use Spectrum modem with WiFi, you may get an all-in-one router/ WiFi and be charged the 5 dollars. If you don’t want the $5 charge, do you buy a modem and a router? I researched the list of authorized modems that Spectrum provides and these are modems without WiFi. So are you supposed to replace the Modem and then also get a WiFi router? Is there a list for compatible WiFi routers? or am I not understanding something?
Correct. The only charge is for managing wifi on their routers. No charge if they are not managing wifi--so yes, free modem use.
Bringing your own modem doesn't change a whole lot in most cases, other than allowing you to see more information about your modem (logs, signal levels). In some specific cases, you may have access to some troubleshooting features, but they aren't exactly game changing-- more something for our inner geek to tinker with and gather a little more info before opening a support ticket.
Either way, the modem will negotiate channel specs, timeslicing for transmission., etc. with Spectrum's head end just the same. You cannot even update the firmware and such--all of that is done from Spectum's end.
5 -
if you were to get a gateway, ie a combo modem/router in one device, you can have Spectrum place the gateway in bridge mode, which basically disables the router portion of the gateway including wifi, and then attach and use your own router for wifi. hence no wifi charge.
correct. You don't have to buy your own modem unless you want to technically be responsible for it.
Yes, you can use the Spectrum modem supplied by Spectrum, and then buy and use your own router & wifi. Most people do this to forego the $5 wifi charge.
The advantage to buying your own modem is that you can see the signals page so you know whats going on if you have issues. The downside to owning your own modem is that Spectrum will not provide you ant technical support for it ,as it's your modem and hence your responsibility to figure out yourself what the modem issue might be. Assuming it is a modem issue. It could be a line or tap issue which is their responsibility to fix.
No it doesn't change your charges if you decide to own your own modem and or wifi router.
I was using a Spectrum router with my own router and wap (wifi access points) .
I decided I didn't want to mess with my router and wifi config anymore so Spectrum sent me a Spectrum Modem and Router (2 pieces) and I now pay $5 for their wifi.
For most plans, the price of the plan includes a cable modem. There are very few plans which will require you to buy your own cable modem, or be charged a $10 per month rental fee. (ELP for sure; maybe SIA). So unless you are on one of those low-price low-speed plans, take their "free" modem, and let them worry about it.
When you are on one of those plans that requires you to rent a modem, it makes sense to buy the modem, as it will surely pay for itself within a year.
Many here recommend that you own your own router, to keep the cable company out of your LAN, and so that you can set it up the way you want to set it up. The rule of thumb is to take their free modem, and manage your own LAN by buying a separate dedicated router that YOU control.
6
You can basically use any router, just make sure it has a gigabit internet (WAN) port (they are pushing the standard tier to 200mbps, so the older 10/100 ports will bottleneck things).
If they issued you a combo unit, you do not "have" to get them to swap it to a regular modem. They can set the bridge mode on it so that it functions as a standalone modem. Having a standalone modem may be more ideal though (power consumption, size, etc).
So I don’t need to buy a modem if I want to use my own WiFi router. I can use the Spectrum modem and just get any WiFi router with gigabyte internet (WAN)? What is the advantage then of buying a compatible Modem? It doesn’t change your charges does it?
