Spectrum TV app not working on IPad
EmilEmil Posts: 1
I have an iPad Air 2. It has IOS 13.7. When trying to stream live tv programs to the iPad using the spectrum app, I get audio but no video.
Streaming to this device from the live tv category worked as expected before, but not now. Can you help me make it work?
  • James_MJames_M Posts: 2,459 ADMIN
    Oct 19, 2020
    Have you tried deleting and reinstalling the app?
  • ReneeDReneeD Posts: 1
    Oct 20, 2020
    I am having the same problem. I have deleted and reinstalled the app several times. It fixes for about 15 minutes and then goes back to no picture. The app also does not work on an Orbi Router only the Spectrum router. I have called Spectrum regarding both issues and have not been able to get a fix for either problem.
    edited October 20 Oct 20, 2020
    @ReneeD,
    What is the model and OS of the Apple device you are using?
  • purpleprincesspurpleprincess Posts: 1
    Oct 22, 2020
    Spectrum app not working on any device, android, apple, roku, for days.
    Yes restarted internet, yes uninstalled and reinstalled app on all 3 devices.
    Other apps work so what the problem?
    Oct 23, 2020
    @purpleprincess
    Sounds like you having a similar but different issue. For direct assistance, please begin a new post and include the device models, operating systems and speed test information. Thanks!
  • BarbredhoofBarbredhoof Posts: 1
    Oct 24, 2020
    iPad Air and spectrum tv app not working for us either. I noticed that the app version shows up as 0.0 after repeated uninstall reinstall attempts. Ok on IPad mini in the same house. Version 8.3 of the app. On the iPad Air the iOS level is up to date at 12.4.8. The app worked fine until about 10/15
  • Julia_RJulia_R Posts: 4,414 Lead Mod
    Oct 24, 2020
    • Hi @Barbredhoof I am seeing that the most recent OS is 14 for most devices. Our app updated towards the end of September. A few things to check is open storage space on the device. I have found on my Apple devices that when I'm close to the limit apps in general don't work very well. I offload some of my less used apps and things start to run more smoothly. Also a full reboot will sometimes do the trick.
    • iPad Air (4th generation)
    • iPad Air (3rd generation)
    • iPad Air 2
    Those are the iPad Air that should be able to have the 14 More on that here: iPadOS
    Julia_R
  • HightideHightide Posts: 3 ✭✭
    Oct 28, 2020
    iPad Air version 12.4.8
    Same issue as above ...
    this is clearly an app issue. Please resolve.
    Oct 29, 2020
    App states it will work in IOS 12 and up.
    should’nt need iOS 14
    spectrum, please resolve this issue.
    Oct 29, 2020
    Good Afternoon!
    Just wanted to let you all know that if you are having difficulty with the app and are seeing that download listed as 0.0 this is something that we are aware of and are working to correct with the release of the next App version which should be 8.10. I do not have a date for this but do know we are working quickly to get that available as soon as possible to get this issue corrected.
    Julia_R
  • M1006PM1006P Posts: 2 ✭✭
    Oct 31, 2020
    So your saying iPad Air with iOS 12.4.8 will never work now or in the future?
    Oct 31, 2020
    @M1006P Not saying that. Not at all. We are aware of a problem with the app and are working to correct that with the next update. They are working on getting that out as quickly as possible. Should be in the very near future.
    Julia_R
    Nov 02, 2020
    Thank you everything working now.
