Can I login to Spectrum webmail from Europe?
Heather_T
This discussion was created from comments split from: Login From Europe.
  • Heather_T
    Hello @slough! Welcome to the Community.
    You'll definitely just want to make sure to test out the VPN prior to leaving the country. Set up would depend on the specific VPN you're using but once you have it downloaded most come with a step by step installation guide. Once you have it installed try logging in to the VPN to verify that you can access your email and navigate the internet without any issue.
    Heather
  • slough
    slough Posts: 4 Novice
    Heather_T,
    It would be difficult to test a VPN for my situation without being outside the USA. I was in Europe about two weeks ago and loaded a recommended and popular VPN. I aimed the VPN at a connection in Chicago. I was still unable to send charter.net email.
    Installation of the VPN was quick and easy. I don't recall any options besides choosing the location of the VPN server.
    What settings should I be looking for?
    Thanks, Dave
