Cannot clear Recently Watched channels
Gator5000e
Gator5000e Posts: 5 Novice
For the last few weeks, I am not able to clear Recently Watched channels on the Apple TV 4K 2021. This is happening on 2 separate units. Going into settings and then to RW channels and then clearing them does nothing. I’ve rebooted the modem, TV and Apple TV boxes. And I’ve completely uninstalled and reinstalled the app on both devices. Still can’t clear the recently watched channels.
Please submit this to the development team to review and hopefully fix soon. Plus I’ve already submitted this issue to the twitter team.
Thank you.
    William_M Posts: 1,667 ✅ Verified Employee Moderator
    Hi @Gator5000e, welcome to our community!
    I was able to locate your account using your community registration and your modem is still reporting an up time of 59 days. Will you please try rebooting again but make sure you remove the power cord for 30 seconds and all the lights go dark before plugging it back in? Wait for the online light to come back on and then reboot the router the same way. I also recommend checking your Apple TVs for software updates.
  • Gator5000e
    Thanks, William. I rebooted the modem via the My Spectrum app but will try unplugging it when I get home. I am not really sure what the modem has to do with the recently watched channels. Seems to be the app is not clearing cache. But I will give it a try.
  • Gator5000e
    Unfortunately the full reboot did not help. I am convinced it will have to be an app fix to remedy the problem.
    Did you check your Apple TV for software updates? Do you have any other devices you can try the app on?
  • Gator5000e
    Both Apple TVs are up to date with OS updates and both Spectrum TV apps are up to date as well. As I said before, this only happens on the apps for the Apple TV. The apps for my iPad clear recently watched channels properly. So I will hope an app update fixes the problem.
