Xbox Series X screen cutoff on hallmark channels
Masked_Bandit
Masked_Bandit Posts: 2 Novice
The screen is cutoff when watching the hallmark channels on the Xbox series x. I know this channel does not normally extend fully, but this is actually cut off further than that. The “k” on the hallmark watermark is cut off on the right side of the screen. Is this channel half price?!
  • Masked_Bandit
    It has always been this way as long as I can remember, I reinstalled the app at the request of support, no change. I’ve looked through all the settings, nothing affects it. It is only on the hallmark channels, as far as I know. Yes, I’ve rebooted everything and no change. One interesting note, there was one commercial that went full screen, then it went back to being cut off.
    Are you able to test with an Xbox Series X?
    HT_Greenfield Posts: 1,377 Contributor
    edited September 2023
    Edit: Just curious if all three of the Hallmark channels are covered by your subscription and appear and correctly display via the Spectrum cable TV set-top box and then also via watch.spectrum.net on another device apart from the Xbox and then also via the Spectrum TV app on any device apart from the Xbox.
  • Rreals
    Rreals Posts: 1 Rookie
    edited October 2023
    Not the Hallmark channel, but have the same issue with TCM. Chatted with Spectrum and they were unsure how to fix. Both xbox 1 and xbox series x have the issue; however, looks fine on roku.
  • Brandonease
    Brandonease Posts: 1 Rookie
    Has anyone found a solution for this? Exact problem here. We have an Xbox one and only the Hallmark channel has this issue on the spectrum app. Other hallmark channels are unaffected. Both main show and commercials experiencing this issue. Any help would be appreciated!
    @Rreals : This shouldn't be relevant to TCM but just curious if you could pull up one of the Music Choice channels e.g. Soundscapes. It should display full screen with no distortion in any case but just curious if it does via Xbox.
