What can I do to keep my phone from freezing? I have used up most of my available storage.
Marqus22
Marqus22 Posts: 1 Newcomer
edited December 2023 in Digital Phone
I thought I bought more storage but it doesn't seem to make a difference??? I only have 32gb total internal storage.
    Hello @Marqus22
    Welcome to our community! If you are referring to your cell phone, the option to add additional storage would depend on the device. If the device accepts microSD cards, you can insert one into the device to use as additional storage for photos, videos, and downloaded content, though it will usually install apps to the internal storage. Most Samsung and Motorola phones will accept microSD cards, where iPhones do not. If you check the instruction manual for the phone it will say if the device does and where the tray for the card is located.
