Cable connection and Eero WiFi set up
PaulN
Posts: 1 Rookie
Hello, I have an Arris combo modem and router Model TG1672G, with connections to Spectrum via a Coaxial cable. This allows for me to have Wi-Fi, Cable TV and phone. I want to set up a Mesh Wi-Fi system such as Eero. What would be the best way? Do I get need to disconnect one item or change out the combo modem router to something different?
Unless you're streaming your Arris isn't affiliated with your TV service.
You need to have an ethernet cable connected to your modem to your Eero router.
Just get a free modem from Spectrum
And make sure your firmware is up-to-date on your Eero router.
But keep in mind Spectrum can't troubleshoot your Eero if you have an issue with it.
