App not working on wifi
My app only works on mobile data but not when I connect to wifi. It used to work fine and I've tried uninstalling it already
    Hi & welcome!
    Looks like you are getting errors on Roku. Can you try restarting the modem and then if the issue continues, please restart the Roku from the settings menu.
    Let us know if are still getting an error.
