XUMO Upgrade is terrible!
Filou
Filou Posts: 1 Newcomer
Anyone else is having issues with Xumo? I wish I never "upgraded". Don't if you don't have to. Losing connection every hour.
    Edward_T Posts: 573 ✅ Verified Employee Moderator
    Hello @Filou;
    Welcome to the Community Forums. I can understand the frustration of the Xumo not connection properly. I checked the logs of the app and confirmed that it is having issues with the internet connection. I analyzed your modem and it is online with no history of cable signal problems. I logged into the Spectrum router and optimized the settings to see if it helps with your connection. If the problem occurs again then I would recommend you reset the modem by unplugging the power for a minute. This may restore the connection to the Xumo to normal. If this does not help then please reach back out to us so we can investigate the issue further.
  • Nuford05
    Nuford05 Posts: 3 Spectator
    I bought into the xumo thing for savings. At first didn't upgrade all the boxes in the house, but after seeing the big10 app on xumo allowing me to watch both men & women basketball or baseball & softball games on my computer & TV when they play at the same time was a big positive. I've had big thoughts of just buying one xumo to keep that access of watching games simultaneously. There really isn't an advantage other than price in comparing a xumo box to the hardwire boxes. I'd go back to the hardwire boxes in a second if the price of the two boxes were the same.
    Hello @Nuford05;
    Thank you for the feedback on the Xumo. I will pass on your feedback to management.
