High split in Anthony Texas 70821
I we received message that network upgrades had been completed about 1 month ago and still no simetrical speeds. Any time frame
Hello @roger731
Welcome to our community! I show that the high split construction has been completed, though we haven't been given a launch date for the symmetrical speeds in the area. Once the speeds are available, you'll receive a notification as either a text or email depending on your account communication settings.
On average about how long does it usually take from the completion date to the symmetrical speed launch in the past from other cities and areas
There's not an estimate or average time as it depends on the infrastructure in your area. If there's extensive construction or hardware upgrades needed, it can take longer than areas that may not need as much work. For example, some areas need to have new nodes or hubs built as a part of that construction or may require the hardware in the existing ones to be upgraded.
