Spectrum TV app with Roku goes black random times while watching - RESOLVED
gcorreia56
gcorreia56 Posts: 25 Contributor
Only have had this problem with the Spectrum app. No problem with Netflix, Amazon Prime, Youtube. Screen will go black and no sound. This happens at random times while watching Spectrum TV. To get the channel back, I use the back arrow on the ROKU and then go back into Spectrum app. This is an annoying bug. It happens with all my ROKU devices only when using the Spectrum app.
«13
    Hello @gcorreia56
    Sorry to hear you're experiencing issues with the Spectrum TV app on your Roku. We are happy to look into this for you. The app works in conjunction with your internet modem. Please sign out of the app, reboot the modem then sign back into the app. Let me know if this helps.
  • andymp3
    andymp3 Posts: 13 Participant
    edited November 2023
    Yes, same thing here. Only answer ever seems to be reinstall app, reboot, etc etc. But a quicker way to get it back is hit right, bring up menu, change channel back and forth.
  • AndyRules
    AndyRules Posts: 2 Novice
    Having the same issue with our Roku app. Any resolution to this issue yet? Seems like it started happening last month or so.
    @AndyRules & @gcorreia56,
    What you are describing is caused by connectivity issues. In most cases, restarting the modem resolves these issues. Even if it has been restarted recently, please try restarting another time. If the issue continues, you can check out this link for app troubleshooting.
  • Unknown
    edited December 2023
  • Thisted
    Thisted Posts: 1 Rookie
    Mine does this at 7:10 am and 7:10 pm every day.
  • mdifranco
    mdifranco Posts: 3 Novice
    I am seeing the same thing. it happened tonight at 7:10 to me. This is not an internet issue I have looked at my throughput on my router and there is no drop in service and my tv is connected via ethernet. This seems to have started with the latest release 11/17/2023 build date. I have seen this some additional times beyond the 7:10 times also. This is most definitely a Spectrum bug in the app. It does not act like connection errors. I even tested this by disconnecting my tv from ethernet and also testing disconnecting my modem, both of these tests produced connection errors but did not make the spectrum app go black. I have also reinstalled the spectrum app, hard reset the roku tv and did a full factory reset on the roku tv.
  • AndyRules
    Can't say I noticed the time, but when it happens I hit rewind button to go last channel and it starts working again. Definitely just started doing this mid November, so I had a feeling it was from an update. My wife and daughter will be streaming on other TVs just fine and dandy, but only Spectrum ROKU app seems to be glitching
    @AndyRules, @mdifranco & @Thisted,
    What you are describing is typically caused by connectivity issues. In most cases, restarting the modem resolves these issues. Even if it has been restarted recently, please try restarting another time. You may also need to restart the Roku from the settings menu.
    @gcorreia56,
    Thanks for restarting your modem. You may also need to restart the Roku from the settings menu.
    What you are describing is caused by connectivity issues. In most cases, restarting the modem resolves these issues. Even if it has been restarted recently, please try restarting another time. You may also need to restart the Roku from the settings menu.
    @gcorreia56,
  • mdifranco
    I have tried all of that and more. Have you submitted a ticket to the development teams to look at the differences between the 11/17 release and the precious release. This many people would not be seeing this issue for the first time all of the sudden if this is truly a connectivity issue.
  • 6146229605
    6146229605 Posts: 1 Rookie
    The "going to black" on Roku is a prevalent issue. Everyone reports the same conditions: all other streaming services are fine. This is a Spectrum issue that actually requires investigation --- this isn't a subscriber issue. Again, no other streaming services are problematic. Stop being dismissive of widespread problems.
    @mdifranco,
    At this time, there are no widespread issues impacting the TV app on Roku. The issues described in this thread are consistent with individual connectivity issues. Even though your modem was restarted recently (6+ days ago), restarting it again, along with any connected routers, will usually resolve the issue. Even if it only resolves the issue for a short time, and the issue returns again, that is information that can be useful in additional troubleshooting.
  • Reevest
    Reevest Posts: 1 Rookie
    I’m having the same issue as well with the black screen. Hitting the back arrow fixes the problem until next time. Like everyone else it is not an issue with any other streaming services. It is definitely a Spectrum issue. I’m posting only to show there are others having the issue too.
  • Fritome
    Fritome Posts: 1 Rookie
    Having same problem. Started after update mid Nov. 2023
  • 356476
    356476 Posts: 1 Rookie
    I’m having the same issue with the app cutting out/ crashing. It’s definitely an app problem. I have tried everything even buying a new Roku and factory resetting my tv and still have the same problem. If this problem persists I’ll be looking for another service provider!!
  • mdifranco
    I am happy to restart my modem again but this sounds more than an isolated issue. With its randomness I am sure it is just not being reported yet. There is a fair amount of people on this thread that all have the same issue all beginning with the update on 11/17.
  • Unknown
  • Mmcfar
    Mmcfar Posts: 1 Rookie
    we are also having the same issue. Have not noticed it at a specific time but it happens every evening night and during the morning.
  • jj893
    jj893 Posts: 1 Rookie
    I have been having this issue since Spectrum updated their app on 11/17/23 version 11.2.0. I have no issues with connectivity and all other apps work fine. Its not my modem, router or switch.
  • Jim_M1
    Jim_M1 Posts: 1 Rookie
    I've had the same issue with the screen just going black at seemingly random times. Have rebooted and reinstalled everything with no help. It is definitely a Spectrum App issue as this did NOT happen until the last Spectrum app update. I'm a Senior Electrical Engineer, have spent over 40 years designing and troubleshooting electronics and software. Spectrum needs to have someone look at the latest app update and find the software "bug" that obviously exists..
  • Woody56
    Woody56 Posts: 1 Rookie
    For quick resolution (NOT FIX) - when you are on the black screen... hit your remote button that launches the "Spectrums Quick guide" (the one that pops out from the side of the screen), then hit the ok/select button (your channel should already be highlighted). It will pull the channel out of the black.
    The Black Screen is reminiscent of other streaming apps that ask you after being idle with your remote for a given period of time "are you still watching?", (the reason that is done is for bandwidth purposes). Personally if you pay for something you should be able to do whatever you want including watch 24/7 without interruption outside of cable's commercial content.
    "Connectivity issues" is the basic simp response because they can pay anyone to write prewritten responses. Many sites use bots, and the response (even though has a name) is just A.I.. There is probably a tracking counter that flags this issue once soo many hits on this page have happened. In fact I wouldn't be surprised if I triggered a response from James.
  • knowhow55
    knowhow55 Posts: 4 Novice
    Still happening MST - random times.
    Please fix the app.
  • knowhow55
    Please fix the Spectrum app going blank with no sound randomly.
    Pushing the guide arrow will start it back but it is annoying.
    Thank you
