High-Split Converter wont stay connected to tivo?
dan706
Posts: 4 Novice
yes
the High-Split Converter want stay connected to the tivo
Thank you for confirming that. Through the system, we were able to find your associated account. The behavior concerns you're seeing are something we'd recommend setting up a tech for. Would you be ok for us to go ahead and get that in for you so our field team can get this behavior squared away?
I am having that same issue. I can’t access my channels after installing the High speed splitter. I was on the phone with cable card support for an hour last night, but no resolution.
