High-Split Converter wont stay connected to tivo?
dan706
dan706 Posts: 4 Novice
edited July 7 in TV Equipment
    Hello @dan706
    In order to make sure that we're understanding your situation to provide the right information. Are you in a high split area and your TiVo isn't working after the conversion?
  • dan706
    yes
  • dan706
    the High-Split Converter want stay connected to the tivo
  • Kelly_M
    Kelly_M Posts: 110 ✅ Verified Employee Moderator
    @dan706
    Thank you for confirming that. Through the system, we were able to find your associated account. The behavior concerns you're seeing are something we'd recommend setting up a tech for. Would you be ok for us to go ahead and get that in for you so our field team can get this behavior squared away?
  • Metalrat
    Metalrat Posts: 1 Rookie
    I am having that same issue. I can’t access my channels after installing the High speed splitter. I was on the phone with cable card support for an hour last night, but no resolution.
    Lyn_T Posts: 827 ✅ Verified Employee Moderator
    Good evening @Metalrat and Welcome to our Community Forums,
    I am sorry that you are missing the channels after changing up your equipment. Are you receiving an error message or are the channels just blank/not there at all? -Lyn
