selwynator
selwynator Posts: 12 Participant
Recently switched from Spectrum box dvr to cloud dvr. I’m using roku to connect to the Spectrum app. Seeking to resolve two quirks:
1) On playback of some recorded dvr shows, the show will freeze. Sometimes it will freeze 5-6 times on playback. Only happens on Spectrum app, not others. Verified internet speed is 500Mbs. Anyone else experiencing this and found the cause?
2) Also, why is that Spectrum doesn’t show video frames when fast forwarding through a recorded show? How are we supposed to know when to stop fast forwarding if you can’t see where you are? Is Spectrum working on an update to correct this?
«134567…10
    Good evening @selwynator and Welcome to our Community Forums
    Thank you for reaching out to us about your streaming services. I am sorry you have noticed this concern. I recommend that you attempt to reset all the internet equipment. This can be done by unplugging the cable line, power line, and removing the battery backup if you have one for both the modem and the router for a solid 3-5 minutes. Are you able to try this and let us know? The video frames when fast forwarding or rewinding with the Cloud DVR is not available at this time. -Lyn
  • Susanb
    Susanb Posts: 3 Novice
    We are having the same issue. Have to reboot everything and many times it still doesn't fix the problem. Half the time we can't finish watching a show we started. We had our own modem that was older, so got a new one from Spectrum to see if that helped. This is just not a good system. Totally agree about fast forwarding too. Why isn't Spectrum working on this???
  • selwynator
    edited February 2024
    @spectrum (Lyn_T): I tried everything you suggested above and it did NOT help. Appears this technology was released without adequate testing. Okay, mistakes happen. Just fix it now so customers can have a better experience.
  • selwynator
    Exhausting all troubleshooting scenarios I could do, I called Spectrum “technical support”. Zero help was provided, except for rebooting everything (usual response). Of course, it did not help.
  • blpenna
    blpenna Posts: 1 Novice
    edited April 2024
    I've called several times on the Spectrum App for DVR Cloud! I had technician come out to tell me they had to put in a ticket for the App dept to see what was wrong. The recordings freeze up, cut off last 10 min of the shows. I have to fight to get shows to play because it boot off and I get the 3 dots like it's thinking. Then kicks off with an error code. I call and am told to jump through hoops of rebooting modem, rebooting system, delete app and reinstall. It's not working! So Spectrum tell truths! Does your Spectrum App DVR "Cloud" work?
  • Ruben_R
    Ruben_R Posts: 110 Spectrum Employee
    I am sorry for the service issues that you're experiencing. I'm checking for any issues reported on the Cloud DVR and I'm not seeing any reports on issues. Is this happening on all the devices or just on 1 of them?
  • Chap5971
    Chap5971 Posts: 2 Novice
    edited March 2024
    recorded shows keep freezing up when played from Cloud DVR. What is happening?
  • Phil_B
    Phil_B Posts: 301 ✅ Verified Employee Moderator
    Hello-- This is a known intermittent issue with Cloud DVR recordings. No ETR at this time, but it is being investigated and hopefully resolved soon. We appreciate your patience-- thank you!
  • Rich76
    Rich76 Posts: 1 Rookie
    I am having the same exact issue. Would it be possible to provide an update to when this is finally resolved. I plan on monitoring this thread. Since at least I now know I am not the only one. Sad because it was working great until this started to happen.
  • Timothy46
    Timothy46 Posts: 11 Participant
    Happening to me too. The spectrum app completely crashes daily.
  • kcw1996
    kcw1996 Posts: 2 Novice
    edited April 2024
    I am unable to watch any shows recorded on my cloud dvr. I am using a fully updated Windows 11 PC and connect to the internet via my home network in my home. Have tried using Chrome and Edge browsers
    I always get error Reference Code: WUP-4003.
    I am able to watch the recorded shows on my phone and tv (using AppleTV)
    William_M Posts: 1,839 ✅ Verified Employee Moderator
    Hi @kcw1996, welcome to our community!
    There is a known issue with cDVR causing intermittent functionality. No ETR at this time, but we hope it will be resolved soon. We appreciate your patience.
  • kcw1996
    It’s been over a year. It can’t be an intermittent issue
    Sorry about that, if you've been having issues that long it's probably something else but at there is currently an issue with the app which will likely complicate any troubleshooting efforts until resolved, but we can certainly get started.
    Are you having any issues watching Live TV on your computer? Do you have a VPN, anti-virus, or any other software on your computer which might affect the internet connection which you can pause?
  • cinsob
    cinsob Posts: 1 Rookie
    I also am having zero luck successfully watching shows on the cloud DVR. Tech came out and could not get it to work either, suggested I go back to a old style DVR box. So frustrating.
  • ltcolumbo0
    ltcolumbo0 Posts: 10 Participant
    I feel your pain as Spectrum Support is no help, even failing to contact you after committing to level 2 support. It feels like Spectrum does not care to address bugs in their Cloud DVR, nor are they interested in enhancing features that would put it more on par with other cloud DVR platforms like YouTube TV. Because of this, I do not plan to stay with them much longer.
  • Heatherm
    Heatherm Posts: 3 Novice
    this is the worst cloud dvr. I have experienced instability (excessive buffering, sometimes going to black and never coming back, stuttering) in playing back recordings that are actively recording. No issues streaming live TV or playing back recordings that have finished. This happens on Roku and Apple TV .
    This is ridiculous when I pay extra for this. Can you have the developers actually fix this problem instead of customer service reading me fixes that don’t work like unplug everything, uninstall the app etc?
    I want a credit on my bill until this is resolved
  • RhodesCD
    RhodesCD Posts: 1 Rookie
    We just also switched to spectrum cloud DVR and we are having the same issues. the power resets did not help a bit. I called spectrum and they said this is a known problem and they are working on it.
  • Dadaven
    Dadaven Posts: 7 Participant
    I can't get thru a recorded ballgame or movie on either my tv or ipad without buffering/stopping/restarting on the ipad or stoppage with three dots or error message that my program is not available on tv. I have reset both the modem and router but the problem continues. Very unreliable and frustrating.
    Hi @Dadaven, welcome to our community!
    Are you having any problems watching Live TV, or is it only an issue with recorded content? Have you run a speed test to make sure your internet connection is fast?
  • Dadaven
    Playing recordings is the problem. Just tested Internet speed on Spectrum site and it was 236, not the 500 of our plan.
    James_M Posts: 5,673 ✅ Verified Employee Moderator
    @Dadaven
    Does the issue still happen if you try viewing the recording on a different device?
  • Dadaven
    Yes, on both tv and ipad
    Thanks. There was a known issue with Cloud DVR and the issue has been resolved. Please try testing with a new recording and let us know if the issue continues.
  • DCB55
    DCB55 Posts: 2 Novice
    The issue still remains
  • Dadaven
    Yes, still a problem here.
  • Philip4868
    Philip4868 Posts: 1 Rookie
    I have the problem as well. Been worse this past week.. GMA recorded this AM continually errors STRP-4004.
  • AppProblems
    AppProblems Posts: 21 Contributor
    From the beginning, Spectrum Cloud DVR & the Spectrum App ( Samsung TVs—using Roku & AppleTV) has been an ongoing problem w/constant issues. Latest problems this month are DVR records half of programs, usually the last 32 minutes of a show, playback is a nightmare w/constant freezing, buffering & now blurred out of focus images. Last night I had to get out of the app over 10 times and go back into it. Nothing worked. I have reset, restarted re-everythinged-- the app, my TV, Roku & nothing is helping. Still have audio/ video syncing problems on & off that have gone on well over a year. None of this is new. Spectrum knows the app has had issues all along. Will it ever be resolved?
    edited March 2024
    @Dadaven
    Thanks.
    Please delete the app, restart the device and reinstall the app, then try testing a recording again and let us know if the issue continues.
